Leakdown Test on a Cold Engine - Seller Says this is Useless?
Old Oct 6, 2011 | 10:14 AM
RabidRat's Avatar
Default Leakdown Test on a Cold Engine - Seller Says this is Useless?
So I bought a motor off Sonshine Autoparts and had my shop do a leakdown test on this engine.
The results: 88% leakage on cylinders 1 and 2, 55% leak on cylinder 3, 20% leak on cylinder 4.
Obviously this is terrible so the shop advised me to send it back, which I did.
Ultimately, here was Sonshine Autoparts' reply after they received it back. I'm not sure what to make of it, can you guys comment?
I won't go into a pissing match with your mechanics but after assisting in the diagnostics of this engine,right off the bat my guys questioned a leak down test on a cold engine ,they explained to me that engine cylinders are never perfectly round but oblong to compensate for heat expansion therefore you would never be able to get a properly sealed engine when its cold.
Feel free to contact me for further explanations
Thank you
Don Laniel
dlaniel@sonshineautoparts.com
Old Oct 6, 2011 | 10:48 AM
T-Smac's Avatar
He is correct. If the engine was in fact cold, a leakdown test will not be accurate. The pistons expand as they heat so they will "fit" the cylinder better. This is why you don't want to rev high until the car is warmed up.
Those readings are terrible. So terrible that you would have noticed it driving. Actually I doubt it would even go anywhere with 88% on 2 cyls and 55% in another.
Old Oct 6, 2011 | 10:49 AM
T-Smac's Avatar
If the shop didn't know to do the test on a warm engine, I doubt they can properly set the pistons to TDC (top dead center) which would explain the terrible numbers
Old Oct 6, 2011 | 11:15 AM
RabidRat's Avatar
The motor was never installed, I asked the shop to test the motor to make sure it was ok before they put it in.
Should the leak be completely different between all the cylinders? I would expect more leak than usual but I would not have expected 88% in one and 20% in another, that's quite a difference.
Old Oct 6, 2011 | 11:30 AM
street_ruler's Avatar
i dont think that it matters that the piston is at TDC. it matters that the valves are closed.
and yes, a cold leak down test isnt the greatest but an 88% leakage is not even close.
to me these numbers sound like either one of two things, a test that was performed with a valve half open or a reallllly bad motor. was a compression test performed?
Old Oct 6, 2011 | 11:31 AM
oh, and pistons are not "oblong" they are almost perfectly in round so they expand correctly to a ROUND not oblong, hole.
Old Oct 6, 2011 | 11:48 AM
T-Smac's Avatar
It must be at TDC of the compression stroke. A good reading would be less than 10% in all cylinders. 10%-20% is acceptable.
Old Oct 6, 2011 | 11:55 AM
D-Jetronic's Avatar
They failed to acknowledge the basics, i would not do business if i were u
Old Oct 6, 2011 | 11:59 AM
T-Smac's Avatar
The piston skirt is in fact an elliptical shape
Old Oct 7, 2011 | 02:40 PM
LS What?!'s Avatar
It doesn't matter if it's at tdc or not. As long as the valves are closed like street ruler said. Or just loosen the rockers so they won't open the valves. Which would be easy on a motor on a stand.
