Leaking diff mounts
Old Oct 17, 2015 | 11:30 AM
mikefifth's Avatar
Default Leaking diff mounts
Hi.
Rear diff mounts are leaking.
would ideally like spoon as my engine and trans mounts are spoon however I can't warrant the cost.
I know innovative do a cheapish set of mounts but I had bad experience with their engine mounts so would like an alternative if available.
Now I've been thinking, could I use some rigid collars on the diff mounts and use it like this or can rigid collars only be used with good mounts?
Old Oct 17, 2015 | 11:39 AM
Slowcrash_101's Avatar
They're both leaking?
Old Oct 17, 2015 | 12:01 PM
mikefifth's Avatar
Both the rear mounts are leaking, yes.
I replaced them with second hand OEM two years ago as the previous factory OEM ones failed.
Thinking about upgrading to solid mounts instead of these fluid filled ones.
Old Oct 17, 2015 | 12:51 PM
meccjoo's Avatar
You can try hardrace or Megan, they are hardened rubber like the Spoon mounts.
Old Oct 17, 2015 | 01:14 PM
zeroptzero's Avatar
You can fill them with liquid urethane if you are up for it. Some have been successful with that.
Old Oct 17, 2015 | 03:05 PM
mikefifth's Avatar
I've seen the diy. Could be worth a shot.
Old Oct 17, 2015 | 06:47 PM
chefs2000's Avatar
I think that the collars will hold them rigid even if broken cause the they kind of sit in the lip of the mount and when tightened down that's it its snug..
[attachment=86425::]
Amoson
May 15, 2018 05:09 PM
Js S2k
Sep 4, 2008 12:43 PM
pinoyk20
Feb 20, 2008 08:58 AM
bodo
Sep 17, 2007 04:08 PM
naishou
Apr 19, 2001 03:14 PM
