Leaking oil through headgasket
Before you flame me on this I had just recently changed my headgasket and i used arp headstuds. I have heard on hear that you are suposed to exceed the 22 foot pounds with the instal of these. I only torked to the honda requirements "22lb". Could this have caused my oil trickle problem. I am leaking oil right below the tension all. I also used gasket sealer in the designated place around the timing chain im just lost. Im tempted to remove the v cover and cams and rockers and just retork.. Help!!!!
As per another thread, ARP head studs should be torqued to 80ft/lb with ARP moly lube and 120ft/lb if using motor oil. Its def a start if it's not the problem it should be done anyways. The bolts weren't designed for stock torque spec so use the ARP mnfc. instructions.
This is going off memory, so it may be a little off, but the 22ft-lb is the initial torque. You are then suppose to torque the head bolts 3 more times, each time turning the bolt 90 degrees following the torquing sequence in the manual, so you were way off even using 22ft-lb's for the ARP studs. Next time, read the instructions first.
I should add, that if you've been driving the car at 22 lbs of torque you best pull the head and put a new headgasket on since you likely ruined that one. you're lucky you didn't suck in a bunch of water and really cause problems.
You should have read the actual oem instructions, your head is barely bolted on. I don't think I'd risk it if the car was run more than a few minutes in the current config. Replace that hg imo.
-Ry
-Ry
OEM bolts are torque angle, 22ft lbs to start. Then 2 steps of 90 degrees after on a used bolt. 3 step of 90 degrees on new bolts.
Like it's bee stated, the headbolts on your car are barely tight.
Thanks dumb move on my part I just misread the directions. I tore it down last night to reveal that it was leaking oil from every edge the block but I got lucky and there was no water in the cylinders. My cometic is on its way and I am def going to tork a 80lb. Thanks for he help.
zeroptzero
Dec 13, 2011 03:16 AM
