Leaking radiator
So, I noticed that my radiator is starting to leak at both top corners where the plastic tank meets the core. I'm gonna order an aftermarket radiator instead of going back to stock. I was thinking about a Koyo but found this on eBay and wondered if anyone else has experience with an eBay radiator like this one:
My link
Anyone foresee an issue with this?
My link
Chances are it might work just fine, but on a critical part like a radiator I'd stick with a Koyo as my first choice. A no-name rad doesn't cut it for me, and I'm not too sure about chrome on a radiator ?. If you want a less expensive rad Mishimoto are less money and still pretty decent quality. Your talking about rads that will likely last the life of the vehicle, I'd pay a bit more money for a well known brand, if I'm not mistaken Mishimoto have a lifetime warranty, not sure about Koyo.
No one? I could've sworn I saw an install write-up a while back on here but cannot find it... I don't see how this one could be bad considering that it also has a lifetime warranty.. I'm just hoping for input from someone who has used one before I pull the trigger.
I had a Mishimoto radiator, the construction of it is pretty decent, it worked well, and it has a lifetime warranty. I've been told that some racing teams in Japan us that rad. I did notice that is was very thick, which can interfere with some aftermarket intakes and superchargers etc, I think it is 3 inches thick if I recall, so you should check to make sure you have enough room in the engine bay for that rad. Other than that it worked fine, cooling was never an issue. Mishimoto rad caps are known to be crap though, they give you one with the rad but I would plan to replace it with a better aftermarket cap like Spoon, Mugen, J's, etc.. . I think the Mishimoto retails for about $240.00, not a bad deal for all aluminum construction.
Originally Posted by s2000maniac
My buddy has a OEM radiator that came out of his 2008 s2k with 47,000 miles. He replaced it coz he went turbo. It's for sale if your are interested.
