a little advice
im replacing my clutch tomorrow and was just wondering if you guys had any tips or things you can share about doing this job (problems/solutions)
your input is greatly appreciated! thanks
ok 1 tidbit:
Steering coupler...with the steering unlocked, loosen the top bolt, and remove the bottom. Use a marker to matchmark the coupler to the steering rack.
NOW....pull the key out of the ignition and lock the steering. THEN slide the steering couple upwards and off the rack.
If you don't do this, and the steering wheel is allowed to rotate 360, you will break the cable reel in the column.
