Locked out of 3rd gear
Old Jul 4, 2016 | 05:15 PM
starchland's Avatar
Default Locked out of 3rd gear
I have a problem with my ap1, only ever happens on the track shifting at redline. Won't let me into 3rd gear, never grinds. Just feels like a lockout, if I ease up on the Rpms it will let me in but then I'm losing time.New oem clutch and slave/master. Did it with the old oem clutch as well. Fresh fluids all around - amsoil,Clutch greased and shifter greased, free play minimal. Maybe it's just me? Also I have 75a motor mounts which I suspect...anyone else have an idea?
Old Jul 4, 2016 | 08:39 PM
Car Analogy's Avatar
Yeah, I was thinking motor or trand mounts. Things moving around under load. Check those...
Sent from my SM-G920P using IB AutoGroup
Old Jul 5, 2016 | 12:32 AM
starchland's Avatar
Btw only locks me out on the upshift, not downshift to 3rd.
Will check the trans and diff mounts (both 75a)maybe they need to be reset/realigned. Not sure if this would have an explanation for it or not mechanically.
Thanks
Old Jul 5, 2016 | 05:26 AM
windhund116's Avatar
What weight of Amsoil tranny oil you using?
Thanks!
Old Jul 5, 2016 | 10:11 AM
starchland's Avatar
Amsoil mtf synthetic
Old Jul 5, 2016 | 11:55 AM
dwb993's Avatar
Synchronizers? I recall seeing a post by Billman that said to go through all gears up to redline and back down a few times to get them back in line. He also mentioned to not skip-shift.
Old Jul 5, 2016 | 03:00 PM
Well, tranny oil seems fine.
Old Jul 5, 2016 | 05:59 PM
starchland's Avatar
All fluids have a few hundred km on it only. I feel the issue is mechanical In nature
Old Jul 6, 2016 | 03:45 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I did have one customer that had a problem getting into third, because the engine/trans were shaking back and forth too much. During fast shifts (he was shifting too fast anyway) he would hit the "side of the gate" so to speak.
I recommended mounts or an Engalls ETD, we have not done the job yet.
Old Jul 7, 2016 | 01:40 PM
starchland's Avatar
Maybe I am trying to shift too fast. But I wouldn't expect that to not let me in the gate. Mounts are good, maybe I will try going back to oem. Car has about 160k km. 3rd gear never gives me an issue otherwise. Maybe I will play around with the free play, maybe I have too little, been running this amount of free play for many years though.
