Looking for pics of F20C engine parts...
In particular, I want to see what the main bearing carrier looks like. As I understand it, the F20C uses an aluminum "ladder type" main bearing carrier that signifigantly increases bottom end rigidity. I recently bought the "Honda S2000" book from www.motorbooks.com but there weren't very many pics of the motor. Being a genuine motorhead I am really impressed/thrilled with the F20C. Real pride of ownership. The F20C has some really incredible features such as the carbon-ceramic cylinder liners, roller-bearing cam followers, the above mentioned bearing support and so much more. If anyone has a link for some pics of the F20C (disassembled) I would greatly appreciate it if you could pass it along to me. Thanks in advance...
Best regards,
Matt
Best regards,
Matt
Ladder? Did somebody say ladder?
More pics of our engine torn apart during the our bottom-end replacement:
http://albums.photopoint.com/j/AlbumIndex?...&a=10527402&f=0
First off, thanks for posting the pics. If it's not too much trouble Mark, I'd still like to see the pics of your motor when it is apart. Why is your motor coming apart? Doing anything interesting or is that G-11 classified information? What happened to your piston Jason? Did it seize up? Sure looks rough. I read somewhere on the board that someone cracked a piston. I also noticed that the combustion chamber looked awfully dirty (Carbonized). How many miles are on the motor? I've never taken apart a car motor, but I did tear down a motorcycle engine (91 GSX-R1100, 1216 cc air/oil cooled motor) and the piston/combustion chambers were much cleaner. Granted, it was a high compression motor (12.5 to 1 static) and I always ran a pump/race fuel mix so maybe that's why there was such a difference. By the way, I'm not sure what part was the main bearing carrier. I'm assuming it's the bottom of the block that is holding the main bearing caps, but I was under the impression it was a bolt-on piece and it looks more like part of the block to me. Any ideas? Anyway, thanks again for the replies and the pics...
Best regards,
Matt
Best regards,
Matt
The HyperRev magazine specializing in the S2000 has some very good pics of the entire engine disassembled. I don't have a scanner, but perhaps someone else that does can post these pictures, or you could buy one (though expensive, about $35).
By the way, I'm not sure what part was the main bearing carrier. I'm assuming it's the bottom of the block that is holding the main bearing caps, but I was under the impression it was a bolt-on piece and it looks more like part of the block to me. Matt
