Loose seat back
Originally posted by mas
My driver's side seat back seems to move sideways (left/right). Is there a way to remove the play? It is quite obvious when making turns, otherwise not noticeable. Thanks!
Tuner
Originally posted by HondaS2000Tuner
Just taking a stab at it but maybe some bolts are loose?
Tuner
Tuner
Anyone with a helms? I'm not even sure if the service manual will cover this.
The seat back is attached to the "Recline Adjuster" by 2 bolts (35 ft/lbs). The "Recline Adjuster" is attached to the outer seat track by 2 bolts (35 ft/lbs). This "adjuster" is covered by ......... you guessed it - the "Recline Cover". On the inner side, the side back is attached witha "Pivot Nut" (16 ft/lbs).
Begin your quest in these locations.
Are your seat track securely fastened to the floor?
I don't know why I find these things funny still. I'm such a pervert
