Low pressure windshield squirters?
Old Nov 23, 2006 | 09:27 PM
trivium's Avatar
Banned
Default Low pressure windshield squirters?
I noticed that my windshield squirters have lost pressure. When I turn them on, they goon full blast the first second and then start dripping out barely. So I have to push the rod that turns them on , up and down so I can shoot at full blast. Anybody know of a solution to repair this?
Old Nov 24, 2006 | 03:17 AM
CoralDoc's Avatar
Top off your fluid reservoir .
Old Nov 24, 2006 | 11:30 AM
Z06-KILLR's Avatar
and if you have already tried Coral's fix, then try cleaning the nozzles with a needle...sometimes you can have some was or other obstructors there that prevent the full splash...
Old Nov 24, 2006 | 12:17 PM
iam7head's Avatar
jamming stuff in more usually does more harms than good.
here now i do mine when it's jammed, use a air gun and blow it out, sometime it works sometime it doesn't.
if that doesn't work, try use a throttle body cleaner, give it a drop or two into the inlet, just make sure that stuff doesn't touch the paint.
the stuff should desolves wax and tar, etc
Old Nov 24, 2006 | 12:46 PM
Beechjetdriver's Avatar
I used a compressor to blow the nozzles clean from the inside, underneath the hood, after disconnecting them from their respective hoses. Frequently using drive-thru car washes which spray clear coat protectant following the wash will eventually clog the windshield washer nozzles with wax.
DSCLegend
Feb 9, 2010 07:30 AM
s2gZ
Nov 24, 2007 07:30 AM
Saab9-3
Apr 25, 2002 03:43 PM
RoadTrip
Jun 23, 2001 04:44 PM
Zsr31
Apr 17, 2001 01:22 PM
