Lowering my S2K
Old Aug 14, 2004 | 01:01 PM
n'C Honda's Avatar
Default Lowering my S2K
I was wondering if it is necessary to do a 4 wheel alignment after I lowered my car with kg/mm race springs with OEM shocks? Help please
Old Aug 14, 2004 | 01:06 PM
terd ferguson's Avatar
yes
Old Aug 14, 2004 | 01:08 PM
BlitzSRM's Avatar
Will it go all the way back to the stock setting. that is will tires wear out evenly after being dropped?
Old Aug 14, 2004 | 02:48 PM
The alignment has a lot more adjustment than most cars. You should be able to achieve stock settings if you don't go much lower than one inch. The factory camber settings are negative, so your tires may wear on the inside a little more than an Accord, for example, but not much.
Old Aug 15, 2004 | 06:53 AM
n'C Honda's Avatar
Thanks guys...WHat about If I'm having coil-overs? Will the camber be negative as well? Do I need alignment in this case?
Old Aug 15, 2004 | 08:28 AM
Yes, it will be the same situation.
Old Aug 15, 2004 | 09:44 AM
dispader's Avatar
When I had mine aligned after installing KG/MM race springs the guy couldn't get it to the exact stock specs. I later got it re-aligned to the UK specs (which I recommend, but the tires will wear faster).
Old Aug 15, 2004 | 01:42 PM
north9586's Avatar
I heard the UK specs make the car feel like you get understeer going into corners. Just curious what your take on it was?
~Andrew
LivingLegend
Aug 4, 2004 01:01 PM
taki
Aug 25, 2003 10:52 PM
TIMELESS
Feb 17, 2003 09:24 PM
T.O.-S2K
Apr 6, 2001 12:13 AM
T.O.-S2K
Apr 5, 2001 06:02 AM
