Lowering Springs-Good or Bad?
Old Dec 29, 2005 | 06:53 PM
VIC4UF's Avatar
what makes the KG/MM better than say eibach or H&R springs?
Old Dec 29, 2005 | 07:51 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
They are progressively wounded springs,and the quality is top notch!!!
Rear is 448#,and Front 398#.
Old Dec 29, 2005 | 09:20 PM
VIC4UF's Avatar
^^I'll pretend that I know what that means
Old Dec 29, 2005 | 09:42 PM
Balboa's Avatar
I'd imagine that means 448 and 391 lb/in, as in the spring rate.
Progressive-rate is self explanitory.
Old Dec 30, 2005 | 03:48 AM
I did not mean MPH for sure.!!!
Old Dec 30, 2005 | 07:08 AM
Tugz_S2K's Avatar
Banned
Do a spring and damper combo at least. Lowering springs, no matter what brand, will decrease handling performance and will also overwork and prematurely wear out OEM dampers. Changing springs only is ghetto....
Old Dec 30, 2005 | 10:04 AM
bulldogs2k's Avatar
yup, the stock handling is good enough but if you want the look then go for it. it will wear out your suspension either way.
A
Old Dec 30, 2005 | 11:21 AM
Very sorry,but I don't agree.!!!
Cheap springs,only for the sake of lowering,can,and most of the time will,decrease the stock handling of the suspension.
But a good,properly calibrated spring/shock combo,will do wonders,compared to OEM;you will run circles around a stock "S".
Remember,there is always place for improvement.!!!
Old Dec 30, 2005 | 01:32 PM
Tugz_S2K's Avatar
Banned
^^...umm, what's the difference from what you said to what I said?
I said do a good spring and damper combo, dont only do springs....springs only will suffer.
Read dude
Old Dec 30, 2005 | 01:37 PM
If I can't read,at least,I can write.!!!
"Ce que l'on concoit bien,s'
