lucas heavy duty oil stabilizer
I was just curious if its safe to use this product? I have high mileage s2k and it burns some oil and sometimes smokes a little too. They also have a full synthetic version too. Thanks
http://www.amazon.com/Lucas-10001-He...oil+stabilizer
http://www.amazon.com/Lucas-10130-Sy...oil+stabilizer
Oil additives aren't necessary at all, and personally, I think it's just a namebrand snake oil. You could be smoking because of the oil you're using, assuming you don't have an issue with valve seating or rings.
It's a known fact that Mobil 1 causes our engines to burn up oil pretty bad. If you're using M1, I'd suggest switching Castrol, Amsoil or Motul. A good quality oil will not need additives to make it do the job better.
Lucas makes good a product. I use the oil stabilizer mixed as directed with Royal Purple 5-30w. Limits the oil burn in my ap1. I would and do use it. I noticed less oil burn no puffs of smoke at startup. Quiet cold and hot start ups no dry starts at all. Lucas works good mix per directions try it.
^Thanks I know but more is going on than what you say. I would not just add thick oil. IMO I would use Lucas stabilizer in my cars mixed per directions with correct oil.
No one here will change my mind on this we will talk after 300k miles.lol
Do what works for you I guess. I tried it in a couple of my other cars and didn't notice a difference. That's why I have zero faith in it. But if you like it, and it works for you, then cool
Well if you look at the lucas oil yes it is thicker but another thing you will notice it is sticky like honey. It coats and sticks to the surface to be lubricated. It tends to stay on part while car is off not drip back down to oil pan. Just adding thicker oil would be a problem I would stick oem weight oil. I would just stick to the lucas topic. I think its good to use in any car.
No problem on debate. All good.
I have used both but right now I am using the HD mixed with the RP. As stated above. I think the HD works better for oil burn but both works well. For my ap1 I noticed much less oil burn. Seems to work for me I change it out with new oil every 4k miles with new oem filter.
I used to get smoke puffs at startup sometimes. That has gone away and much less burn. It is warm/ hot where I live and 110k miles on S.
I drive DD and vtec from time to time 9k rpm as well. I do change oil on time if not before required miles.
I feel a 9 k motor should get better attention in regards to oil and sooner frequency of oil/filter change.
I never had any problems with this product it is good for assembly oil as well.
