Made a mistake, will I be ok. Reset the CEL.
Old Jun 19, 2006 | 09:11 PM
EVAN_In_A_SPA's Avatar
Default Made a mistake, will I be ok. Reset the CEL.
My car got a CEL over a month ago, I was very sure it was nothing big so I just reset it. It just came on while I was on the freeway going over 90mph.
I reset the light the next day and then fueled my car, I noticed the gas cap was not tight. When I took it off it didn't click and came off with ease. I've been over a month since then and the light never came back on. I've driven a little over a thousand miles since then, should I be ok in assuming that the lose gas cap caused the CEL. Since the light came on when I was going over 90 on the freeway, I'm ASSuming that maybe the change in speed caused a fluctuation in pressure in the gas tank because the gas cap was loose.
What do you guys think.
Old Jun 19, 2006 | 09:39 PM
xviper's Avatar
I think you shouldn't make assumptions and not clear CELs until you know for sure what it is. One day, it'll hurt big time.
Old Jun 19, 2006 | 10:07 PM
darkfx's Avatar
Honestly?
I think you're a moron. the CEL is there for a reason, its not there so you can "just reset it" . Next time you are "very sure its nothing big" is when it will bite you hard in your ass.
Old Jun 20, 2006 | 12:25 AM
SIIK2NR's Avatar
Next time pull the code so you know for sure what caused the CEL. Us telling you everything will be ok does not make problems go away.
Pull the code and do a search and you will have more piece of mind in knowing you actually fixed the issue.
Tim
Old Jun 20, 2006 | 01:52 AM
SenderGreen's Avatar
Originally Posted by darkfx,Jun 19 2006, 10:07 PM
Honestly?
Ah c'mon, tell us how you really feel.
Old Jun 20, 2006 | 08:18 AM
Squeezer's Avatar
there is a TSB on 02-03 and o3 S2k's that have a damaged gas filler and the gas cap won't seal properly because of that. I'd go by the honda service dept and get the TSB done.
Old Jun 20, 2006 | 08:52 AM
Originally Posted by darkfx,Jun 20 2006, 12:07 AM
Honestly?
Which is why I put I made an "ASSumption." Because it was a stupid move.
Now that we all know I made a stupid decision.
Could the gas cap cause the CEL to come on, since it never came back on. If it would have came back in a week, then i would have worried.
Old Jun 20, 2006 | 11:43 AM
NFRS2kSi's Avatar
go over to autozone & check out...
if it was gas cap..
u should get 2 codes regarding
evap "####"
Old Jun 20, 2006 | 11:58 AM
xviper's Avatar
Not likely you'll get both.
The gas cap/fuel filler neck will be the code for fuel tank system (P01456).
The other EVAP code will be for the cannister system (P01457).
Old Jun 20, 2006 | 02:16 PM
stitos2k's Avatar
Coming in here and saying you cleared a cel code... Well you're better off handing a loaded gun to a 3 year old.
Too many people have cleared codes without knowing what it is and have their car require a few $K to fix, when if they'd read the code to begin with it would have cost a couple hundred.
Ap2S2000
Mar 24, 2010 10:26 PM
jlammy
17
Oct 2, 2008 01:49 PM
nosyajg
Sep 26, 2006 09:56 AM
EVAN_In_A_SPA
Jun 19, 2006 09:13 PM
west2000
Jul 31, 2004 10:26 PM
