Maintenance needed at 49k miles?
Old Mar 18, 2007 | 04:57 PM
wasupdu's Avatar
Default Maintenance needed at 49k miles?
I've always done all of the maintenance on my cars in the past but over the 3 years I've owned the s2000 I really haven't done too much in terms of maintenance. The car drives just fine, but since I pulled the cover off of the car the other day I figure there's probably work that needs to be done.
'00 black s2000 with 49,000 miles. I changed the trans fluid (GM Syncromesh) last year as well as the diff fluid (Mobil 1). I just changed the oil for the season (Mobil 1) but what else needs to be done?
I did a quick search, but I'm sure I missed something. I bought the car used in '04 but didn't get any manuals, paperwork, etc... with the car.
mods:
K&N FIPK
Passport Escort 8500 x50 hardwired
XM Sportscaster hardwired
Garmin Nuvi 350 hardwired
Sony HU
Infinity speakers (headrest/doors/rears)
10" Alpine sub
2 - Kenwood amps (1 interior speakers + 1 sub)
20% visibility tint (driver & passenger side)
SS mesh grill
hardtop strikers
Rick's leather console cover
Rick's VooDoo shift knob
Rick's "s-badges" on front/rear/steering wheel
17" wheels
**not really much of a mod**
ability to lower the top while moving (thanks s2ki.com )
Any suggestions greatly appreciated.
Old Mar 18, 2007 | 05:08 PM
kill's Avatar
check the manual..it should say...i personally don't have mine here right now..but when i get home i'll break it out and let you know..i'm bookmarking this thread.
Old Mar 18, 2007 | 05:17 PM
whitemistress2k's Avatar
I'd check/replace the cabin air filter...
Old Mar 18, 2007 | 05:42 PM
wasupdu's Avatar
Oh yeah, I did that too. Thanks for reminding me (thanks to you too hardtopguy).
Old Mar 18, 2007 | 06:09 PM
Cool...
Clutch and brake fluid flush and fill perhaps?
Old Mar 19, 2007 | 06:30 AM
vtec9's Avatar
45,000 miles/3 yrs Scheduled Maintenance
Recommended service for your 2000 Honda S2000:
Replace coolant; use Genuine Honda Antifreeze/Coolant mixed 50/50 with water.
Replace brake fluid; use Genuine Honda DOT 3.
Replace engine oil.
Rotate tires.
Replace engine oil filter.
Inspect front and rear brakes.
Check pads and discs for wear (thickness) and damage.
Check calipers for leaks and check tightness of mount bolts.
Check parking brake adjustment. Should be fully applied within 9 to 13 clicks.
Inspect tie-rod ends, steering gearbox and rack boots.
Check steering linkage for looseness.
Check fluid lines for damage and leaks.
Inspect suspension components.
Check bolts for tightness.
Check condition of ball joint boots for deterioration and damage.
Inspect driveshaft for cracks and check boot bands for tightness.
Inspect brake hoses and lines (including ABS). Check the master cylinder, proportioning controlvalve and ABS modulator for damage and leakage.
Check all fluid levels, condition of fluids and check for leaks. If needed, add transmission fluid, engine coolant, brake fluid, power steering fluid, and windshield washer fluid.
Inspect cooling system hoses and connections.
Check for damage, leaks and deterioration.
Check for proper fan operation.
Inspect exhaust system. Check catalytic converter heat shield, exhaust pipe, and muffler for damage, leaks, and tightness.
Inspect fuel lines and connections. Check for leaks.
So, basically nothing but fluid changes and inspections.
register at honda owners link http://www.ahm-ownerlink.comand you can get the complete schedule
Sickdayracing
16
Sep 5, 2008 07:43 AM
wasupdu
Cars for Sale
Jun 14, 2007 01:47 PM
530s2k
Cars for Sale
May 20, 2007 03:03 PM
Sickdayracing
Cars for Sale
Aug 11, 2005 03:39 PM
