map sensor electrical connector
Old Oct 4, 2012 | 02:47 PM
rjbecker12's Avatar
Default map sensor electrical connector
DOES ANY ONE KNOW THE PART NUMBER FOR THE ELECTRICAL CONNECTOR FOR THE MAP SENSOR ON 2003 S2000. IT IS GRAY WITH THREE WIRES AND ONE OF MINE IS LOOSE.
Old Oct 5, 2012 | 03:38 AM
Blk Prl's Avatar
are you refering to the harness? I don't think you can buy just the connector. You may be able to fix a loose wire
Old Oct 5, 2012 | 08:29 AM
MM3Kwolik's Avatar
If your connector is bad find someone parting out a harness and you can replace just that connector. If you're very careful it can be done with some small flat head hobby screwdrivers.
jaundice
Feb 23, 2010 08:30 AM
ap1chick
Oct 12, 2008 09:09 AM
