MAP Sensor issue
Old Oct 6, 2010 | 07:56 PM
MasterForce's Avatar
Default MAP Sensor issue
So i went out and changed my MAP sensor to a 4-bar map sensor because i will get it tuned next month. after i change it i also reset the ECU. i try to start the car. and well nothing. it seems the engine tried to start but instantly dies. not even pressing the throttle while starting will make it work. so i tried to start the engine for 15 minutes with the same result. i decided to put the stock one back in and it worked.
now the question. why wont the new 4 bar map sensor work? do i need to wait until the tuning part to install it? Thanks!
Old Oct 6, 2010 | 07:59 PM
Slows2k's Avatar
Stock PCM's need stock MAP sensors. Different MAP sensors have different operating ranges and voltages.
Old Oct 6, 2010 | 08:09 PM
so i have to wait until i get it tuned to use it?
Old Oct 6, 2010 | 08:16 PM
s2k dre's Avatar
Yes! U have to change the settings in the ecu. Otherwise the car wont run.
Old Oct 6, 2010 | 08:17 PM
s2k dre's Avatar
Do u have flashpro??
Old Oct 7, 2010 | 04:34 AM
yea i have flash pro. right now my ECU has a reflash from hondata for the s/c kit
amdaman
May 20, 2015 01:35 AM
pinstriped06
Dec 19, 2009 04:05 PM
Jonsey Boy!
Feb 13, 2008 09:34 AM
nalVle
May 7, 2007 06:46 PM
Fivenines
Apr 4, 2003 07:52 AM
