Is this a Map Sensor issue
Old Jul 25, 2012 | 03:21 PM
OneSilverS2k's Avatar
Default Is this a Map Sensor issue
Alright I have a 2002 S2000 with 103,000. After driving the car and starting it again I press the pedal down and there is no power like a bog, then it jumps ( like a jolt ) and it is perfect and I never have that issue while driving. This never happens on cold starts! Any ideas!?
Old Jul 25, 2012 | 04:40 PM
MM3Kwolik's Avatar
Hmmm....could also be TPS?
Old Jul 25, 2012 | 05:56 PM
I get no check engine light, but Like I said only after the car has been start, I take off in first and it is like a "bog" then I just it a little more gas and JOLT boom it good.
Old Jul 25, 2012 | 06:03 PM
MM3Kwolik's Avatar
Weird....
Old Jul 25, 2012 | 08:03 PM
rob-2's Avatar
Just started happening recently? How hot is it? Had this car long?
Old Jul 25, 2012 | 11:24 PM
crisskro's Avatar
Do you have an aftermarket intake? Sounds like heat bog, especially now that it's hot outside.
TPS rarely gives a check engine error. At 100K miles, the O2 sensors could use a change as well...
Old Jul 26, 2012 | 04:44 AM
starchland's Avatar
what happens when you unplug the map sensor and then drive the car? Also, if you go WOT does the problem clear up?
Old Jul 26, 2012 | 06:27 AM
It's not because of the heat, it did this when I bought the car. I don't have to give it WOT, it ony happens after the car has been driven. I get back into the car start it, idle 110%, so to take off feels like no power, I push down a little more get the jolt and I am all set. Car is 100% stock.
Old Jul 26, 2012 | 11:39 AM
Ideas....?
Old Jul 26, 2012 | 12:55 PM
MM3Kwolik's Avatar
Have you done what was suggested and unplugged the MAP sensor and drove the car?
