MAP Sensor not working
Well my car was running fine earlier today, went shopping for a little and when i hoped back into the car it started right up then a light came on. The car started idling funny and wanting to stall out. Whenever i hit the throttle it hesitates then dies. Went to rent an odb reader and it pulled a P0107 code which is the map sensor and or low voltage. I replaced the map sensor and resetted the ecu but it still does the same.
Update, I was reading through the manual and it said if anything I need to replace my ECM, could it go out just like that? |
have you checked the wiring to the MAP voltage clamp
The car is in limp mode
Where is the black box?
just went and looked the grey connector the wires lead too, sorry thought off the top of my head
Seems to be on tight
if you have replaced the sensor, double checked the connections (pulled the fuse for ecu reset, unplugged and replugged connections, reinstalled fuse)... theres something else wrong im not aware of
i narrowed it down to my MAP sensor not recieving power, would that throw it into limp mode?
