MAP Sensor not working
Well my car was running fine earlier today, went shopping for a little and when i hoped back into the car it started right up then a light came on. The car started idling funny and wanting to stall out. Whenever i hit the throttle it hesitates then dies. Went to rent an odb reader and it pulled a P0107 code which is the map sensor and or low voltage. I replaced the map sensor and resetted the ecu but it still does the same.
Update, I was reading through the manual and it said if anything I need to replace my ECM, could it go out just like that?
