Which marking is TDC in regardings to the crank pulley?
We used a timing light at idle to check for TDC at the crank pulley, there is a red mark and a white mark on the pulley, which one is supposed to be aligned with the arrow on the block. Anyone know?
Umm I couldn't remember it is right or wrong but, you can try this.
It is defend on what kind timing light you using..
If you use base timing light, You should check with white mark on the pulley... If your timing light can advance or retard timing, than set timing with manufacture's spec. than it will be line up with red mark.... (Possible reverse order sorry. can not remember right now.)
[QUOTE]Originally posted by taemin320
