Mechanical O2 Simulator
you drill the top fouler where the o2 sensor threads into then you thread the drilled fouler into the non drilled fouler then into the test pipe so essentially you are stacking the two foulers on top of each other before you thread the assembly into the test pipe - do this before you install the test pipe because you will need to rotate the whole assembly before the test pipe is installed so you don't twist the sensor wires.
Originally Posted by Rusler Firbrand' date='Jan 29 2005, 02:37 AM
running the test pipe w/ the cel codes on, will thsi have any effect on the performance?
