misfire code in number 4
Old Sep 11, 2006 | 07:58 PM
darksides2k's Avatar
Default misfire code in number 4
OK guys heres the story:
I bought the car a 04 s2000 berlina black with 31,800 miles. Now the problem when i bought it, it had misfire codes form 301-304 and p1399. Then i cleared the codes and put in new plugs thinking that would do the trick nothing. Did a search not really what i was looking for. The code then came back on and now it only reads on cylinder 4 misfire. I asked a couple of honda gurus and they think it might be the coil. So i switched the coil from 3 to 4 and from 4 to 3. Now i waited to see if the cel would come back and it did after about 50 miles of driving, reading the same code so i guess it wasnt the coil. Now i am stuck trying to figure out what it might be. It runs fine goes into vtec but idles a little rough and has bad gas mileage does probably about 200-215 miles to the tank. So i am guessing injector but still dont know please help me out here. Thanks!
Old Sep 12, 2006 | 05:49 AM
Ek9's Avatar
Ek9
Banned
You can always switch injectors too to check your theory.
I'd do a compression check. #4 seems prone to problems if people run their '2k's low on oil.
I never saw more than about 20-22 MPG out of mine.
Old Sep 12, 2006 | 08:35 AM
smyroad's Avatar
For my AP1:
All Highway (1 VTEC per 200 miles) 30-33mpg
Mix highway/Local (1 VTEC per 10 miles) 24-26mpg
Spirited (1 VTEC per 1 mile) 20-22mpg
Fall Colors Tour ( Almost continuous VTEC) 15-18mpg
dhayner
May 2, 2014 06:17 AM
JLEEzAP2
20
May 6, 2011 01:15 AM
Eyal s2k
Oct 18, 2010 05:10 PM
sokdo
Sep 21, 2010 11:32 AM
opernator
Nov 30, 2009 06:25 PM
