Miss Shift
Old Jul 15, 2008 | 07:26 PM
erwinxxy's Avatar
Thumbs up Miss Shift
I am a new S ower and drive my S about 2 weeks. Today I was trying to shift form first to second, but i missed it. .. I guess i didn't fully enter the gear when I release the clutch. then i hear a very loud noise like Boom...! from the gearbox i guess. then I saw my gear was in neutral. I drived home later and didn't found any problem. I just wondering if this can damage the transmission.... how bad is it? Thanks Guys!
Old Jul 15, 2008 | 07:50 PM
mikegarrison's Avatar
I was expecting a centerfold. Or at least a hydroplane boat.
You should not have any problem. The 1->2 shift is the most "notchy" on the S2000, and it takes some practice to learn how to do it.
Damaging misshifts are when you end up in a gear too low for your speed, not when you end up in neutral.
Old Jul 15, 2008 | 07:53 PM
erwinxxy's Avatar
Thanks mikegarrison, I will practice more ..
Old Jul 15, 2008 | 07:58 PM
Is the car used? If so, I would replace the transmission oil unless you know for sure that it was recently done. Old oil increases the problem of the 1->2 shift. But it's still the hardest shift to make in the car. 3->2 is the next hardest. For some reason, the design of the tranny seems to make 2 the hardest gear to mesh into.
Old Jul 15, 2008 | 08:07 PM
erwinxxy's Avatar
I bought it certified in a honda dealer, I guess the transmission oil is OK, but i will still check it. thanks for the reminning
Old Jul 15, 2008 | 08:08 PM
chino101's Avatar
It just popped out of gear. Happened to me once.
Old Jul 15, 2008 | 08:54 PM
SCCS2K's Avatar
It's screwed. Time for a new car. I'll take that old thing off your hands if you don't wanna be bothered taking it to the cuber.
Old Jul 15, 2008 | 09:03 PM
21337R's Avatar
Yep, it was partially in gear and when you dropped the clutch the transmission literally kicked it back out. Makes a loud noise but you should be ok.
Old Jul 15, 2008 | 11:06 PM
9kFever's Avatar
1-2 is the hardest shift cause the sychros have to do the most work. It drops 3000 rpms on that shift.
Old Jul 15, 2008 | 11:28 PM
That almost makes sense, except it doesn't make any sense at all. If you are shifting at redline, it drops about 3000 RPMs on every shift.
