Missing Coil Spring Insulator
Old May 13, 2020 | 04:09 PM
Pietai's Avatar
Default Missing Coil Spring Insulator
I was changing my brakes on my driver side front and my suspension is missing a Coil Spring Insulator. My question is the car still driver able safely or i need to replace that Insulator asap. Thank you
Old May 13, 2020 | 10:01 PM
windhund116's Avatar
You're talking about these? Number 10 (top and bottom)? Did you change the springs on your car?
Old May 13, 2020 | 10:11 PM
Pietai's Avatar
Nah just doing my brakes and it super worn at that I could just pull it out just wondering if it’s need or I need it bad before driving the car just the bottom is worn out
Old May 13, 2020 | 11:39 PM
SheDrivesIt's Avatar
Old May 14, 2020 | 12:43 AM
Are you talking about the rubber spacers fitted in between the spring loops? Those are there for shipping purposes, from manufacturer to dealer. They should be removed, once the car is bought.
They are there to limit car movement, while being shipped overseas.
Old May 14, 2020 | 02:46 AM
Pietai's Avatar
I’m sorry man it is item number 10 I said nah for me changing my coils just doing a brake changed and I notice the rubber piece worn out
Old May 14, 2020 | 04:02 AM
Slowcrash_101's Avatar
You don't need them, worst case you get some squeaking.
Old May 14, 2020 | 08:46 AM
B serious's Avatar
Well...Honda would have left them out if they weren't needed.
They do serve a purpose.
They center the spring on the top hat. And they damp noise/vibration. And they prevent the spring and metal tophat from scratching each other and rusting.
They also add about 1/4" or more to the ride height as a byproduct of their thickness.
Every single part on the car has its purpose.
Its probably not an immediate safety issue, but you should definitely replace it.
OP...at some point in the car's life...did the springs get swapped or changed out?
Old May 14, 2020 | 09:02 AM
The spring insulators wear out on their own. I'm willing to bet anyone replacing their OEM shocks probably have worn rubber spring insulators. I agree though, they do serve a purpose, but your car isn't going to fall apart without them.
johnkyr
Jul 14, 2018 05:02 AM
AFK-S2K
Jul 12, 2017 01:53 PM
calebs2k
Apr 28, 2017 02:54 PM
darcyw
Apr 19, 2017 08:21 AM
dlq04
Aug 22, 2016 03:49 AM
