Motor mounts
Old Jul 12, 2019 | 10:29 PM
Ap2Justin's Avatar
Default Motor mounts
Looking for motor mounts as of 2019 my car is completely stock and I need ideas for mounts
Old Jul 12, 2019 | 11:10 PM
gotembro's Avatar
I am very happy with my Ballade sports as of right now
There is not a crazy amount of vibrations just note you need to buy 2 of them.
It looks like OEM but the rubber is soild it's well made but I don't have anything to compare it to; my stock ones were leaking and broken in 1/2; so it's night and day better now.
https://www.balladesports.com/produc...0-engine-mount
Old Jul 13, 2019 | 08:29 AM
cosmomiller's Avatar
Top Answer: 1
OEM.
Old Jul 14, 2019 | 07:18 PM
B serious's Avatar
Why not just buy new factory mounts?
Old Jul 14, 2019 | 07:55 PM
Ap2Justin's Avatar
Wanted to see if there’s anything better
Old Jul 14, 2019 | 08:37 PM
Top Answer: 1
Nope. Especially not with this car. OEM all the way. Even the belts are way better than aftermarket ones.
Old Jul 14, 2019 | 09:41 PM
Kyle's Avatar
OEM truly is the best, and if yours are in good shape and not torn or leaking, keep them.
OEM mounts will serve you well even in boosted applications and the like.
IF you want a more connected feel and don't mind a tiny bit of added nvh, these are the ONLY aftermarket mounts I'd recommend, period.
Mugen
Spoon
Vibratechnics "Fast Road" version ONLY
HardRace "Street" version ONLY
Those are all harder rubber mounts that are solid instead of oil filled like OEM. Do NOT under any circumstance get any kind of poly mount such as Innovative, Hasport, or anything else out there that uses a poly insert and doesn't share the same mounting geometry as OEM. You will legitimately hate your life.
Remember, most engine mounts in a lot of the cars I've seen are typically just rubber inserts. Honda did a fluid filled mount for a reason, and they're roughly double the cost of engine mounts for any of their other cars.
Old Jul 15, 2019 | 12:30 AM
RolanTHUNDER's Avatar
I agree with @Kyle above. 'Solid' choices
Old Jul 15, 2019 | 06:07 AM
Scigheras's Avatar
Pretty damn happy with my Spoon mounts. About the same price (cheaper?) as OEM, engine barely moves around anymore, better shifter feel, and IMHO only (very) slightly more vibrations.
Old Jul 15, 2019 | 06:36 AM
HawkeyeGeoff's Avatar
I like my Megan Racing ones, cheap and very effective. They're just the harder rubber, the car definitely vibrates a little more but it doesn't bother me at all coming from fully mounted cars in the past.
