MPH
Old Dec 2, 2011 | 12:34 PM
BBV S2K's Avatar
Default MPH
So my car when i got it i tested all gears and how many miles i could get in every gear... i dont rember others but i do remember 74-75mph in 6th at 4,500~RPMs... i did an super oil change.. diferential, engine and tranny... now im getting 75mph at 4,000Rpm in 6th... thats a 500rpm less tham before... its that normal or could be the oil? I used OM recomended oils for everything
Old Dec 2, 2011 | 12:52 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Oils dont change anything. You could fill them with peanut butter it wont change your MPH/rpm correlation.
Old Dec 2, 2011 | 12:59 PM
grkboy707's Avatar
Did you change the tires or wheels? Thats the only reason I could possibly think of.
Old Dec 2, 2011 | 03:12 PM
ry4nolson's Avatar
That shouldn't even affect what shows in the instrument panel without a calibrator.
Sounds like you were in 5th when you did the first test lol.
Old Dec 2, 2011 | 04:13 PM
BBV S2K's Avatar
No lol im pretty sure i was in 6th.. and i dont think car will only drop 500rpm from 5th to 6th at 75mph... and about the wheels yes i had first ap1 then ap2v2 but it was the same miles per RPM... but its ok i was just wondering if 75mph at 4kRPM its normal on an AP1... i know the car is all stock just intake and exhaust... (thats all i know)
Old Dec 3, 2011 | 03:11 AM
grkboy707's Avatar
Touche. Haha
Old Dec 3, 2011 | 03:29 AM
ZDan's Avatar
75mph indicated = 4000rpm indicated in the AP1. Only way it was at 4500 at the same speed previously was if the clutch was slipping.
Old Dec 3, 2011 | 04:18 AM
zippity's Avatar
So the fact the the OP changed to larger wheels and tires could not have any affect on his RPMs?
Old Dec 3, 2011 | 06:25 AM
ZDan's Avatar
Different diameter ties will have an effect on ACTUAL speed vs. rpm, but NO effect on INDICATED speed vs. rpm.
Old Dec 3, 2011 | 06:31 AM
rrounds's Avatar
Not by the speed-o, you can put 22" tall tires on or move up to 27" tall tires, it won't change how the speed-o moves with the rpm's. The speed in real life(gps) will change but not on the speed-o. I run taller than stock tires on my "S" and at 60 I gained 2.4 mph, so my speed-o says 60 and my gps says 62.4 my odometer runs slower than real mileage now to.
ROD
