To much fuel pressure?
Old Oct 5, 2019 | 08:59 AM
allansteele's Avatar
Default To much fuel pressure?
i just put in a new fuel pump and now getting 80psi at idle, is that to much? dead pressure regulator?
Old Oct 5, 2019 | 10:35 AM
flanders's Avatar
On a stock car, yes that is too much.
Try replace the FPR, unless you used some aftermarket high flow pump then that could be the cause as well.
Old Oct 5, 2019 | 11:23 AM
s2000Junky's Avatar
Weird. Ive run typical size aftermarket pumps such as the AEM320 and FB340 and pressure goes up to about 55psi at idke if if recal with Stock fpr. But 80psi is a shit ton. What pump you running? Could likely be an obstruction somewhere in return line or fpr.
Old Oct 5, 2019 | 02:21 PM
its a DeatschWerks dw200, says it flows 255 liters per hour. i was getting just over 40 with the stock pump and would increase by about 10psi when i pull the vacuum line to the FPR. I reset the ecu and did a idle relearn, didn't think it would help but did it anyway. right now its about 75psi at idle and jumps to a little over 80 when i pull the vacuum line. i haven't driven it yet, just start and idle.. if that would make a difference
Old Oct 5, 2019 | 02:25 PM
flanders's Avatar
Are you using the same pressure gauge as when you used the stock pump?
Old Oct 5, 2019 | 03:00 PM
yep, same gauge, brand new.
martin j
Apr 27, 2019 11:31 PM
Kyle
Oct 21, 2018 10:28 PM
ninetysixyenko
Oct 13, 2018 08:29 AM
mycrors4
Automotive builds
13
May 2, 2018 03:50 PM
