my engine feels very sluggish recently
my engine feels very sluggish recently, even my gf can feel the lost in power...
- The lost in power cause me very easy to stalk while parking
- too low of a rpm when A/C is on during traffic stops and the engine will shake
- The rpm climbs much slower than before when doing wot highway runs
The heat will do this but you shouldn't be shaking at idle.
Check the following:
Clean throttle body area (my was pretty dirty, this raised my idle and cured the shakes)
Plugs
Air intake filter
Valve Adjustment
Good Luck.
Plugs
Air intake filter
Valve Adjustment
Good Luck.
Yes sir, 5 minute job, buy some carb or brake cleaner. Easier if your not DBW.
I just loosened the intake hose off and moved it to the side.
My car is DBW so I had to use something to hold it open, don't get something stuck back there.
Clean the path of the air flow really well. Raised my idle by 200 rpm.
Yea may be its the heat as well but still, that much difference?
Is there ECU reset for the idle adjustments?
