My poor engine :(
Old Jul 12, 2010 | 04:54 AM
Beksy's Avatar
Default My poor engine :(
Hi my name is Bek, not sure if I have done too much posting on here in the past but thought I'd share my pain...
So basically, a CPU short caused one of my coils to stay on, which then resulted in the following issues
All clouds do have a silver lining though because now I'm getting oversized pistons put in to make my engine be better
Has anyone ever had this sort of thing happen to them??
Old Jul 12, 2010 | 06:13 AM
joes sled 2000's Avatar
Ouch ! That really sucks bad . However , i doubt that youre coil was shorted out . This looks like a sparkplug came loose and let combustion gasses into the sparkplug tube . I have seen this more times than i would like to admit with Honda engines .
Old Jul 12, 2010 | 06:28 AM
INDYMAC's Avatar
One more reason to check/change plugs much earlier than recommended 105K miles!
Old Jul 12, 2010 | 11:25 AM
zeroptzero's Avatar
I find a lot of bolts and parts work themselves loose with this engine as compared to other Hondas, not sure if there is something different about the S2k motor.
Old Jul 12, 2010 | 03:31 PM
Beksy's Avatar
plugs were just changed about 7000km ago, when one of the coils just died.. my mechanic found a short in the CPU when this happened
Old Jul 12, 2010 | 04:17 PM
RedY2KS2k's Avatar
So, how bad is the inside of the head?
Old Jul 12, 2010 | 06:56 PM
Beksy's Avatar
thought I added this one too..
Old Jul 12, 2010 | 07:01 PM
Beksy's Avatar
turns out .. it doesn't show up well in the pic, but turns out that the previous owner or someone had the head off previously and didn't get it machined before putting it back on
Old Jul 12, 2010 | 09:00 PM
Keystone_Subie's Avatar
Always good to get it machined whenever its off, however remember its only a 100% possibility of a good seal if the block is machined too, or else you have a perfectly flat surface against a perhaps not so flat surface
Old Jul 12, 2010 | 09:23 PM
crank's Avatar
is it necesary to have this done everytime the head is removed ? and it can only be done a few times.
