Need answers on MAP Sensor
Old Feb 8, 2008 | 12:22 PM
JimmyB's Avatar
Default Need answers on MAP Sensor
Could someone please tell me what some of the symptoms of a bad MAP Sensor are, other than a CEL?
I am having a major problem with MY01 running very rich. very rough and at an extremely low idle.
The mods I have are a Spoon intake,70mm TB with matching intake manifold. (problems existed with both the stock and modified IM), along with both the Berk Header & Test Pipe.
The car threw 2 CEL Codes: P0170 & P0172. I cleared the codes when I reset the ECU and they have not reappeared.
Any suggestions?
Old Feb 8, 2008 | 07:26 PM
JimmyB's Avatar
Bump for help
Old Feb 9, 2008 | 07:43 AM
Elistan's Avatar
The only symptoms of MAP sensor issues I know of are hesitations at high rpm, as if the spark is cutting out intermittently. I've never heard of a MAP sensor leading to the issues you describe.
I don't know what those codes mean, but I would suggest a compression test - could be a bent valve?
Old Feb 9, 2008 | 02:46 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The usual symptoms of a bad S2000 MAP sensor are:
-Car feels like it kicking in and out of VTEC when under wide open throttle (above 6k)
-sometimes VTEC will be non-existent
Old Feb 12, 2008 | 05:41 PM
JimmyB's Avatar
I finally fixed the problem. It turned out to be a bad gasket between the TB and the intake manifold. Once I changed it out everything was back ro normal.
SHAKYBRAKE
Jul 12, 2018 05:31 AM
Forcedbird
May 19, 2014 08:11 PM
profit_child
Jun 28, 2013 10:40 PM
Live_Wire
Dec 7, 2009 02:16 PM
JohnE
Aug 10, 2005 08:20 AM
