Need help ASAP!
Old Jan 31, 2009 | 01:28 PM
EBinVA's Avatar
Default Need help ASAP!
hello, I need some urgent help with an issue with one of the cars involved in an interior swap. We've connected everything in the dash (all the harnesses/connectors) and we went to see if the car would start and the ignition on position works, but the start button does not start the car. We have battery power, but the car will not turn on. What could cause this to happen? The gauge cluster stayed in its original car, but the harness from the dash did not. Would this cause the car to not start?
Please help ASAP as we need to get this car drivable so the other guy doing the swap can go home tonight.
Old Jan 31, 2009 | 01:53 PM
SC05ap2's Avatar
The starter Button could be bad, did u try jumpong the starter?
Old Jan 31, 2009 | 02:14 PM
aLcm's Avatar
press the clutch down.
Old Jan 31, 2009 | 02:42 PM
negcamber's Avatar
And did you happen to change the ECU?
Old Jan 31, 2009 | 07:06 PM
frofro24's Avatar
I would go over all the connections again, check all fuses, all grounds, and batt. A volt meter might come in handy if you have one. Good chance you missed something. Good luck, I hope you get it figured out.
Old Feb 1, 2009 | 09:23 AM
jdmjeff's Avatar
push it and drop the clutch ... but its prob a ground is my guess
my02s2k1
Sep 15, 2016 03:58 PM
F20-AE86
May 23, 2011 01:44 PM
EBinVA
Feb 2, 2009 04:33 PM
EBinVA
Jan 31, 2009 03:45 PM
Fed
May 26, 2007 03:05 AM
