NEED HELP WITH BEARINGS
Old Oct 31, 2008 | 06:54 AM
  #41
snakeeater's Avatar
The bearings you need will depend on how much (if any) the crank main journals need to be machined to clean up any possible scarring that occurred when the bearing(s) were destroyed. Even if you can't see scarring, you can probably feel it with your fingernail.
The difference between the bearing cap ID and the crank journal OD is the gross clearance. To get the proper net clearance, you need to find the right bearing thickness from Honda's chart. The color codes you mentioned refer to this bearing thickness. Just take the engine to a good machine shop and let them handle it. It's not a job for the layman.
Old Oct 31, 2008 | 07:42 AM
  #42
fadiss2k's Avatar
I bought a used motor that has no scoring at all, but i am rebuilding it with new bearings and rings. I just have never heard of a yellow/green or green/brown bearings.
Old Oct 31, 2008 | 09:24 AM
  #43
SC_Highlander's Avatar
when you buy 'a' bearing, as in a single part from the dealer, you actually receive one bearing, not 'both halves'. So for a rod/crank that calls for 'Green', you need to order TWO green bearings, as each one is a half of the circle around the rod/crank.
So if you need "green" for a rod, you would buy 2 green bearings for that rod. If you need yellow/green, you would buy 1 yellow and 1 green. Green/brown = 1 green, 1 brown.
Old Oct 31, 2008 | 02:33 PM
  #44
fadiss2k's Avatar
ok, i know about the it being 2 bearings and everything. I have never dealt with 2 colors on a single journal before though.
So basically if it says yellow/green ill need to get the top bearing yellow and the bottom green??? Are you allowed to mix 2 different colors in a journal???
Old Nov 5, 2008 | 11:09 AM
  #45
fadiss2k's Avatar
can you confirm what i just said so i dont order the wrong thing?
thanks
fadi
Old Nov 5, 2008 | 03:22 PM
  #46
Yes, you can mix bearing colors within one journal. It also does not matter which color is on 'top'.
Old Nov 5, 2008 | 10:10 PM
  #47
fadiss2k's Avatar
OK! Thanks a million man. I have been waiting over a week to order bearings bc of this! lol
I appreciate it a lot!!!
lookstoomuch
May 15, 2017 04:37 PM
User 32822
Sep 11, 2009 05:40 PM
fadiss2k
Feb 27, 2008 04:34 PM
campbuds
Apr 8, 2006 12:50 PM
