need help / info on installing defi guage
Old Jun 27, 2011 | 03:14 AM
O85o678777's Avatar
Default need help / info on installing defi guage
deleted
Old Jun 27, 2011 | 06:15 AM
Stratocaster's Avatar
Originally Posted by O85o678777
1 off is how i went thru the fire wall , i figure i go thru where the harness go near the clutch by punch thru with the screwdriver
is there other way coz im going to fit 6 sensor wire through
Personally, I would feed the wire though on the passenger's side. Because if you ever have to pull the motor, you are going to have to cut these to get it out. Behind the battery, there is another harness. if you remover the tape, you can push the wires though the grommet with a coat hanger and a little lube (WD40, etc)
2 how should i run the link wire up from the controll to the first guage , i try to find place at the end of the dash but seem like theres no spot
Pull the A-Pillar trim off and you will see the room you are looking for.
3 is the fuel pressure line ,which one is the fuel feed pipe ?
i also got the T adapter for it .
You really should tap the end of the fuel rail for this. The Fuel line is the metal line connected to the fuel rail. You would be cutting this to T it.
4 last question where should i place the control unit
Do you need to touch it while driving? I have seen them mounted under the steering column, but for me that would never work. Your location depends on your size and if you need to touch it while driving.
i have just read about all of that can be found at the under dash fuse box
so i dont have to tap the wire
i found it from this like
can any one confirm this is true ?
Yes, it is true
what kind of male connector do i use to get power from this accessory terminal
Can't you read? The thread you linked stated "All 3 of these connectors are recessed male 1/4" quick-connects". So you don't need MALE connectors, you need Female connectors
Now for my questions, where are you going to put 7 gauges in the car? Why in the hell do you need them anyway?
Old Jun 27, 2011 | 01:44 PM
O85o678777's Avatar
Yes, it is true
yea i just notice after i was in a hurry
i was gonna mount it on the windshield, i got them from a friend , since on one wanna buy it as a set
lude9285
Apr 29, 2016 11:29 AM
brax_1
Sep 3, 2014 07:39 AM
Driv300mph
Nov 18, 2009 01:57 PM
pierceman
Oct 7, 2008 12:46 PM
