Need help with intermittent electrical problems!
Old Aug 15, 2012 | 03:45 PM
ElGingerDeFuego's Avatar
Default Need help with intermittent electrical problems!
So my 2000 S2000 has quickly been developing more and more on and off again electrical problems. They are:
- Speedometer reading about %15 lower than actual speed (this changes back to normal when I push the clutch in after several seconds)
- The A/C would almost randomly blow between cold and warm air w/o the blower turning off. I found that if i accelerate to about 3000 RPM, that is when the condenser would turn off. Now the cold air and the condenser wont occur at all.
- The Radiator fans on occasion will not turn off after turning off the car. It will stay on until either I temporarily remove the controlling relay, or it drains the battery.
- And last, for some reason on occasion, not all the time, the car will just die or stall out when my comes to a stop or when I push in the clutch and hold it in neutral while the car is moving.
I read this... https://www.s2ki.com/s2000/topic/950...-issues-hellp/ and attempted to do the same, but I can't find the 3rd grounding wire set, just the two on the side wall. After this I still have all the same problems, but when I turn the A/C on I can hear the relays controlling the condenser fans and radiator fans clicking loudly from try to switch on and off quickly and doesn't stop until I press the A/C button again and turn it off.
Please help. I've gone to dealerships and several mechanics who have not been able to find the solutions to the problems.
kenlui1995
Oct 11, 2025 08:31 PM
W0Pdego
May 28, 2020 12:30 AM
sleekblackroadster
Sep 10, 2008 06:00 PM
chrisjgiuliano
Jul 10, 2008 12:45 PM
