Need help with Koni&KG/MM setup
Sup fellas. I'm installing Koni yellows and KG/MM race springs next weekend. I need to know what you guys recommend setting the perches to on the Koni's. I also have 17" CE28's. I've done alot of searching and havent really come up with a solid answer as to what works best. I've heard that setting the rear perches to the top and the fronts on the lower will give me a slightly higher stance in the rear. Basically, I just don't want my front to sit higher than the rear. If someone is running the same setup and has some insight, I'd really appreciate it. Thanks
Sime
Nov 16, 2003 06:37 AM
TIMELESS
Nov 11, 2001 01:37 AM
