Need Help on MYO4 Headlights
Old Jun 2, 2004 | 04:27 AM
BustedShox's Avatar
Default Need Help on MYO4 Headlights
I am switching to the MY04 Headlights and I was wondering for you guys that have a 00-03 that did the conversion. Where did you guys mount the HID ignitor box? I haven't had a chance to see where they mounted them on the MY04s but I am guessing they are in the same place as the 00-03.
Old Jun 2, 2004 | 05:28 AM
gerardog's Avatar
Hi,
can't help you with your question, but I was wondering if you are interested in selling the housings of the old headlights...
thanks
Old Jun 2, 2004 | 11:53 AM
BustedShox's Avatar
Old Jun 2, 2004 | 12:32 PM
Dark_Sub_Rosa's Avatar
The 04 headlights, to be placed in 00-03, have to have the ballast moved. Once you get it all you should be able to see where to move the ballast. Have fun with the front bumper too, you gotta do more than just remove the styrofoam.
Old Jun 2, 2004 | 03:14 PM
Xplosiv's Avatar
I was there when the bodyshop worked on my car...it was much harder than i thought
Old Jun 2, 2004 | 04:46 PM
I had to get my cutoff wheel out in my garage when I put my 04 bumpa on.
Old Jun 2, 2004 | 10:14 PM
BlueS2000Boy's Avatar
i just want the 04 headlights. its my understand that modification is not only needed to make a braket of some sort to mouth the ballast box but also you must modify the hole in which the wires travel through. you must make them bigger on your own. don't screw up because if you make it too large hello water.....
Old Jun 2, 2004 | 10:48 PM
Xplosiv's Avatar
^i see you did your hwk jon
Old Jun 2, 2004 | 10:55 PM
don't i always with all my parts.....
Old Jun 2, 2004 | 10:57 PM
Xplosiv's Avatar
i recommand u order the 04 plastic strips that go underneath the headlamps, they are cheap and they do the job
PM HardTopGuy for part #, Honda OEM parts
DeadLock23
Jul 17, 2011 09:49 AM
soulcrew
Mar 29, 2005 05:48 AM
dmcfan
Dec 2, 2004 10:07 PM
kkyntmoon
Dec 29, 2003 03:29 PM
s2oooboy
Mar 18, 2002 12:09 AM
