Need help with passenger power window.
Old Oct 25, 2020 | 07:07 PM
s2000jac's Avatar
Default Need help with passenger power window.
My passenger window doesn’t roll up. And yes I check to see if it was the On/Off switch. Went to see if I get any power to the motor with a multi meter and it didn’t. Check the fuse and it was also fine. Checked to see if I get power to the fuse and I don’t. My driver window and soft top works. Not sure where to go from here. Would greatly appreciate any help.
Old Oct 26, 2020 | 04:59 AM
Slowcrash_101's Avatar
Maybe the motor on the regulator died?
Old Oct 26, 2020 | 06:10 AM
randomwalk101's Avatar
Broken connection somewhere...or may be bad window main controller? I assume you also tried to roll it up from the passenger side switch too and it didn't work?
Old Oct 26, 2020 | 08:26 AM
Car Analogy's Avatar
There are other fuses which can affect windows. Fuses that control something else, but also end up preventing window function.
Is there anything else in the car not working?
Old Oct 26, 2020 | 09:09 AM
s2000jac's Avatar
Do you know which fuses those may be? And everything in the car works perfectly fine, it’s just that one passenger window. When it first happened I could hear a clicking noise coming from the window but it just faded away. It just rolled down one day and never went back up. Was about to buy a new motor but I had to check if it even got power first and it didn’t.
Old Oct 26, 2020 | 09:11 AM
s2000jac's Avatar
I was also assuming it was a bad connection, wanted to see if it could be something else first because I didn’t want to trace a wire down. Haha
Old Oct 26, 2020 | 12:16 PM
rpg51's Avatar
Well, if there is no power to the fuse then probably have to trace it. Do you have the shop manual? I bet there is a diagnosis tree for this in the manual??
Old Oct 26, 2020 | 12:19 PM
s2000jac's Avatar
no I don’t have the manual, I’ll try to look for it. Thank you for the support
Old Oct 26, 2020 | 12:30 PM
stock06's Avatar
Hey,
Hope this will help:
http://s2000.club/OM/2000-08%20Honda%20S2000%20SM.pdf
Old Oct 26, 2020 | 02:41 PM
s2000jac's Avatar
Originally Posted by stock06
ive found something new, hopefully this can corner the problem to make it easier. I connected the window motor to a battery to force it up (which it went up), but then I tried to put the soft top up then the window went back down no problem. I may be wrong but aren’t the window and soft top module connect? Does that mean the problem is there?
