need help with roll hoop plastics.
Old Feb 23, 2004 | 09:39 AM
BlueS2000Boy's Avatar
Default need help with roll hoop plastics.
i need to put the roll hoop covers back on and i know i need to use some kind of adhesive. i was wondering if anyone knew of some that won't whiten th plastic as say super glue does. thanks
Old Feb 23, 2004 | 01:01 PM
ttt
Old Feb 23, 2004 | 02:30 PM
CoralDoc's Avatar
When I took the plastic covers apart in my old car, there was a wire that ran around the juncture of the two halves. I assume that the covers were heat-sealed by applying current to the wire. Now that they're apart, I'd remove the wire and use an adhesive to hold them closed. You'll need to take care that it doesn't attack or discolor the plastic, so try putting a small amount in an inconspicuous place as a test. FWIW, I used Duro brand gel cyanoacrylate glue ("Super Glue") and didn't experience problems with discoloration, but I was very careful to keep the glue from seeping outside the joint. I would think that any general purpose epoxy would work well too. The main challenge is to apply the adhesive in a controlled manner so that you have a neat external appearance.
Old Feb 23, 2004 | 03:09 PM
Rick Hesel's Avatar
Former Sponsor
There is no glue that will hold these together long term. I know from experience, having tried it when mine were removed for the Elda roll bar install. I had to replace both hoops.
I tried every glue known to man, including one type billed by 3M as specifically designed for this type of plastic. If there is any stress on the hoop halves, they will eventually come apart or at least crack open.
Old Feb 23, 2004 | 04:45 PM
damn well that sucks
Old Feb 23, 2004 | 06:11 PM
marcucci's Avatar
Call King and buy the Mugen piece. Show off your hoops.
Old Feb 23, 2004 | 06:17 PM
what mugen pieces are you talking about? if you mean the roll cage i already have a cusco 6pt cage. other wise what interior pieces does mugen make cause i don't know of any. seats, wheel, knob
Old Feb 23, 2004 | 06:40 PM
Rick Hesel's Avatar
Former Sponsor
I think Mugen makes a plastic piece that leaves the roll hoops exposed but finishes off the opening. This mod is popular in some places I've been told. I think you'd want to chrome or powder coat the hoops if you do this, so you won't be saving any money over replacing the plastic hoop pieces, especially since Mugen is likely to extract a heavy toll for their pieces.
Old Feb 23, 2004 | 08:14 PM
CoralDoc's Avatar
[QUOTE]Originally posted by Rick Hesel
Old Feb 23, 2004 | 08:39 PM
cthree's Avatar
Administrator
I guess asking why you took them apart would be a bad question to ask? You don't need to but I guess you know that now.
