Need help with something "simple"
Old May 4, 2013 | 07:27 PM
IwantanS's Avatar
Default Need help with something "simple"
OK peeps how in the hell does this connector come apart?!
Old May 4, 2013 | 07:36 PM
dc2-2-ap1's Avatar
There is a little trigger on the far left side of the connector opposite the bracket that holds it (top of connector in relation to photo). Squeeze it and pull it away from the other connector.
Old May 4, 2013 | 07:43 PM
IwantanS's Avatar
You know I sat here and studied the picture for a while and realized I was pulling the wrong connector the whole time! I was squeezing the release tab but was pulling on the right connector. Stupid.
And then I saw your reply DC, that confirmed it! Thanks man.
Cool, I got the air fuel ratio sensor swapped out. Even by squeezing the release tab really hard and then pushing it down with a screwdriver shaft I still couldn't get the connector off, plus the really tight space didn't help. The problem was that the two connectors were stuck together pretty tight so I had to pry them apart with a thin bladed screwdriver.
Old May 5, 2013 | 11:45 PM
dc2-2-ap1's Avatar
There is also a release tab on the right connector. If you push it away from the connector, and push toward the center of the car, it will release it from the bracket. It makes it easier because you can move the connectors to a better spot to push the trigger and separate them.
Old May 6, 2013 | 10:58 PM
wickwirew's Avatar
haha is that the O2???? When I changed mine I was so frustrated just snipped the whole wire assembly and used butt connectors
Old May 7, 2013 | 02:34 PM
IwantanS's Avatar
Yeah I found that eventually as well and that would have helped! But this will never happen again, "cause it's a Honda!"
Wick: I replaced the air fuel ratio sensor.
KINO
Mar 26, 2013 10:25 AM
xyster
Dec 21, 2011 09:00 PM
hyper-rev
Dec 21, 2011 12:56 AM
sIIooo
Nov 9, 2007 11:50 AM
Scott M
Aug 24, 2003 04:40 AM
