Need help with a SOS Clutch.
Hi Comrades!
Here is the deal.... I've been running SCd @ 300HP and 205TQ almost 2 years on a stock never changed clutch.
I hit 131k miles and would like to upgrade it along with the pulley.
1) I've purchased SOS SPORT clutch (God damn it I just found out SOS clutches will chatter... ARGH)
2) Clutch release & pilot bearing
Question is... Should I buy a slave cylinder? Should I buy braided clutch line? What can I buy to make sure that WHATEVER should be replaced... is replaced at once.
Hi Comrades!
Bill man, more details please. Are you saying to buy all OEM bolts listed above?
S200junky, Should I shell out more dough and just buy the oem friction disc and sell SOS one? Edit: ah gotcha, that's exactly what you are saying.
-OEM disc and bearings. Your bolts can be re-used no problem (provided the are removed properly)'
-any chromoly or oem flywheel
-ACT HO21 or oem pressure plate
(some have had serious engine issues with ACT PP and forced induction combination)
I've have been running ACT H021 PP, comptech FW, and oem disc/bearings for 110k hard miles.
Can you guys please point me in the right direction for the main seal? I know you mentioned Transmission main seal, not the engine main seal im guessing. But where is it? I cant find it on...
hondaautomotiveparts.com to save my life. I checked like every tab. I must not know what I am looking for.
So far I got...
1) SOS Clutch
2) AP1 Flywheel
3) New Fork
4) CAN'T find that main seal you speak of
So far I got...
1) SOS Clutch
2) AP1 Flywheel
3) New Fork
i wish i had when I did it but thought i only had 25k on the car that it should be okay, nope, after 50k, its rattling
