Need Krank Vent info
Originally Posted by jyeung528,Mar 25 2008, 09:39 AM
you should know the pcv is intended for emissions purposes, not performance.
but if a manufacturer found a way to make their engine last longer on any parts of the car or any system on the car, dont you think they would do it, hell, should save on warranty costs right? happier customers? lol
Ok, i think i'm just repeating everything i've said now so i'll stop here. lol
On my final note,
No, it is not worth it in my opinion to use "check valves" on an n/a setup for an additional 0-1hp increase. From the explanations i've heard on an n/a setup, i dont see how putting the krank vents on both sides would make the engine last longer or run safer.
it lowers oil consumption A LOT, on n/a vehicles (as well).
i did not like the fact that the vacuum at idle was pulling on the spark plug tube seals so hard, making them cluck-cluck-cluck...
one_slows2k Posted on Mar 25 2008, 07:23 PM
No doubt.
But in that situation the difference between (1) before and (2) after the throttle body would be minimal, so still very little (if any) flow through the crankcase.
In principle your point is ok IMO, why mess with an OEM system.
But the OEM MY00-03's can consume a lot of oil, and that's not right either.
The KV's reduced oil consuption (clean exhaust tips for miles and miles to "prove" it) on my car.
That's why most if not all N/A cars use them I guess.
ps - you do know there is still vacuum even at cruising right? if you don't believe me put a boost/vacuum guage on your car and run @ a constant speed.
thanks for the replies yall, except for the ricer/stikcers argument
jk...
well krank vents are 100 bukcaroos. but on the link i gave on the 1st post, would it be possible to do it the same exact way on both hoses? (with the supra pcv + other things)
jk...well krank vents are 100 bukcaroos. but on the link i gave on the 1st post, would it be possible to do it the same exact way on both hoses? (with the supra pcv + other things)
Here are some camera phone pictures because I lost my regular camera but you get the idea. It's suppose to flow away from the valve cover. You will know if it's installed correctly when you start your car and try to pull the dipstick out. It'll make a woosh sound.
thanks for the pics asnboy...
not realy planning on buying the real KVs though, wondering if using the supra pcv valve technique would work on both of the lines...if not, i guess i have no choice but to buy the real ones...
musicforthedeaf
Mar 11, 2016 09:47 PM
