Need service manual info for ignition system
Old Jul 28, 2009 | 09:33 AM
Jamison1987's Avatar
Default Need service manual info for ignition system
Hey guys, still fighting the misfire gremlins.
I replaced the plugs, now I'm trying to see if one of my coils is gone.
Could someone post up the service manual pages that deal with the ignition coil packs? Is there a resistance value I should see across two of the pins or continuity somewhere? How about for the ignition wires themselves? Basically I'd like to test the coils before I go shelling out $400 to replace all of them.
Thanks in advance!
Old Jul 28, 2009 | 05:56 PM
SUPERAnimal's Avatar
Find which cylinder is missing then swap out that coil with one that you know is working. If that cylinder keeps missing then do a compression test. If everything is good after that then swap injectors.
Old Jul 29, 2009 | 07:12 AM
Only problem is im getting misfires on all 4 cyl. so the above method wont work.
Old Jul 29, 2009 | 07:59 AM
Stratocaster's Avatar
then head straight to the compression and leak-down tests
GDM S2K
Mar 1, 2006 04:56 PM
aRrakis
Oct 18, 2004 11:20 AM
Revithigher
Jun 26, 2003 05:33 AM
