Need Some Advice!
Old Oct 27, 2015 | 01:22 PM
DirtyDaann's Avatar
Default Need Some Advice!
Hello Everybody first of all thanks for taking your time to help me figure out whats going on with my S. =/
Okay so first things first I've had my S for a long time now over 20k+ Miles 3+ years. I've had this car from my teenage years so I did sadly abuse it. ='(
Now that I'm older and realized the young me was a dumb ass I'm trying to fix up my baby.
Okay so along with my problems first of all car was great when I first purchased it nothing wrong, no shaking, nothing. Awesome!
After my first incident at drift track, I let my buddy drive my car. ='( This resulted in him spinning out and crashing it into the wall with the front right wheel taking all the impact. roughly 30 MPH. It broke this ball joint not sure if that's what it's called here's a picture. Also during that same incident I do a have a video of the whole thing which i might upload. But after hitting the right wheel the car managed to get the rear passenger wheel on top of the stone barricade. ='( after this I had the car in the shop for about a week to have the necessary parts replaced for it to be drive-able again dude to lack of funds. ='( ever since then going over 60+ mph the car will shake from the rear passenger side.
I'm not quite sure but I believe that I have changed the rear lower control arm for a used one from ebay. I know I changed the control arm not sure if it was front or rear more than positive it was the rear. Any who I've been driving with it like that for over a year now. =( Finally got a good lump sum of money to fix my baby. Also to cause within that time to about 8 or so months ago I would occasionally drift my car. Usually when its wet. Since than i have hit a few crubs with the 2 rear tires.
Which brings me to my next issue.
So after I realized how much of a dip shit I was I've been driving regularly like a normal person, I don't drift or race or anything anymore.
So recently in the last month or 2 my rear driver side wheel will make this odd thumb or clunk noise when I go over a bump even the smallest bump.
Below I have a video of the sound it makes when I go over a bump also the picture of what I replaced. I know this seems like a horrible way to treat an S. Probably most of you cringed and hate me for doing such a thing, trust me I hate myself for destroying such an amazing car. But I'm trying to fix it all now and give my S the care and love it needs. So any help at all is much appreciated!!!
Thank you to everyone who took the time and effort to help me diagnose my troubles! I will be posting regularly on the recovery of my S if anyone is interested!
Here's the video showing what I replaced!
[media]https://youtu.be/JVfB8gYArJk[/media]
Here's the video of the Thump Sound
[media]https://youtu.be/dx3klWXjRc8[/media]
Thanks in advance!
DirtyDaann
Old Oct 27, 2015 | 04:11 PM
B serious's Avatar
Get the car in the air. Inspect it for loose suspension parts. Replace what you need to.
The noise could be anything from a sway bar link to a ball joint to a tire glancing off of bumps because you need an alignment. Or a bushing. Or a shock. Or...anything.
Old Oct 27, 2015 | 04:16 PM
Soviet's Avatar
Is your rear subframe lower tie bar removed?
Old Oct 27, 2015 | 04:18 PM
DirtyDaann's Avatar
Nope it's not.
Old Oct 27, 2015 | 04:21 PM
DirtyDaann's Avatar
I've had the car up and inspected by locate tire shops and alignment places nothing loose. one shop told me that i need to get upper control arms to adjust my camber more because they can't align it right for some reason. I'm honestly worried that my car frames bent or something.
Old Oct 27, 2015 | 04:59 PM
B serious's Avatar
Is it lowered? If its stock height, and they can't get the alignment adjusted with the stock adjusters, then something is bent or damaged. Nobody on this forum can tell you what it is for sure. But whatever it is...its likely bent badly enough to see it.
The most likely thing to bend is the spindle. Its also the hardest to see.
Old Oct 28, 2015 | 06:43 AM
DirtyDaann's Avatar
It's stock height, Like i said I've had it up countless times and couldn't see anything. I'll defiantly have the spindle looked at. You don't think it can be my frame bent though? Honestly thats the only thing I'm really scared of.
Old Oct 28, 2015 | 07:24 AM
B serious's Avatar
Yes, it could be a bent or shifted subframe. Or elongated subframe mount holes for the subframe itself or subframe to LCA. Could also be a bent chassis in extreme cases. It could be anything. No definite answers except that the spindles are most likely to bend.
Old Oct 28, 2015 | 07:30 AM
B serious's Avatar
You're not going to be able to just look and see bent spindles...or slightly bent anything else without having a known good part to compare it to.
If anything is bent enough to see...it will be pretty obvious. If it is not bent badly enough to be obvious...then how would anyone know its bent by just looking at it? Unless they have the part's geomtery saved in their memory well enough to spot it (yeah right).
Find a wrecked S2000 with front end damage/known good rear subframe assembly. Remove yours. Bolt the new one in.
Is your car an AP1 or AP2?
Old Oct 29, 2015 | 02:24 PM
DirtyDaann's Avatar
Its ap2 2004 for ill probably try to do that get a whole new rear subframe.
