New owner-engine vibration question - please help
Old Sep 27, 2005 | 08:45 AM
the dumontster's Avatar
this is more or less related to mph, but in my subee, i got sand and snow caked to the inside of my rims. This threw the balance of the wheels off and sent vibration through the car/steering wheel.
Old Sep 27, 2005 | 05:25 PM
Swamibob's Avatar
xviper,
It does not do it while coasting.
I checked the engine mounts today with a friend. I put the parking break on and put it in 1st and released the clutch enough to move it foreward a little then did the same in reverse. The enging did not move at all. Could it be a transmission mount?
Swami
Old Sep 27, 2005 | 06:17 PM
xviper's Avatar
Originally Posted by Swamibob,Sep 27 2005, 07:25 PM
xviper,
Swami
That's not the best test for bad engine mounts, but it'll do for now. The tranny mount is a solid rubber thing. It should not go bad. And if it did, you would see you stick shifter move around like crazy (it normally moves a fair bit).
Given that it does it only when accelerating, I would now suggest you continue your search by targetting the propshaft and the CVs on the 1/2 shafts. If it's your clutch, it would more likely do it during engagement, too.
Old Sep 27, 2005 | 06:23 PM
Swamibob's Avatar
xviper,
How can it be the cv or propshaft whereas it only does it a certain rpms under a load? It does not vibrate if say I take it up to 4500 and then stop accelerating and hold at 4500. Only when the engine is under a load does it do it. Reving in neutral shows no vibration and I had a friend watch the belt and pullys today in the parking lot as I reved it and the belt was smooth. If I take it into honda, it should still be under warranty shouldn't it since the car is just a yr old with 31000 miles on it. Any other ideas?
Rob
Old Sep 27, 2005 | 09:19 PM
xviper's Avatar
[QUOTE=Swamibob,Sep 27 2005, 08:23 PM] It does not vibrate if say I take it up to 4500 and then stop accelerating and hold at 4500.
Old Sep 28, 2005 | 03:20 AM
Swamibob's Avatar
I think you may be right. When I get on it hard it does seem to be happening a little in the lower geard, but 3rd is the worst. I will take it in to Honda and have them check it out. I need to do that anyway since I just bought the car and it has 31000 miles on it.
Thanks
Old Sep 28, 2005 | 09:16 AM
xviper's Avatar
If it'll help, print one of these out and take it to them:
https://www.s2ki.com/forums/index.php?showtopic=275218
Old Sep 28, 2005 | 03:16 PM
Swamibob's Avatar
Thanks a lot man. That does sound like what is going on. Hope they don't give me any shit since it's a 2004 I have.
Swami
Old Sep 28, 2005 | 07:29 PM
esoteric's Avatar
Not to thread jack...
MY01/60,000 miles
I also recently started getting a steady vibration. Almost all speeds/rpms.
My rear tires were completely bald so I thought maybe a seperated belt or something...
On went new Potenzas and brake pads all around, but the vibration is still there.
My thoughts were possibly:
?warped rotors?
?Bad U joint?
?bad CVs? (although they looked fine when I had it on the rack for my tires)
?diff?
I also tried TQing my axles a bit harder as to hoepfully elimante the "clicks", but to no avail.
Old Sep 28, 2005 | 08:27 PM
Slows2k's Avatar
If the vibration is only preset under acceleration, or sustained part throttle, then goes away when coasting it's from pitted/worn inner CV joints. Also possible is a propshaft vibration, but CV's are the most likely cause.
If the vibration gets worse as speed increases, and can be felt throughout the car/back of the seat and doesn't change under accel or decel, it's a rear wheel tire balance issue.
If the steering wheel vibrates under accel or decel, and gets worse as speed increases it's a front tire/wheel balance issue.
A vibration under braking felt through the steering wheel is from the front brake rotors, a rear brake vibration can be isolated by pulling slightly on the e-brake while driving. if the vibration is present, it's the rear rotors.
