Nissan differentials in S2K.
Read about a guy using a 350z axle here a while ago but can't find the thread, 1 hour of searching...
Anyone else tried to build your own kit? Most common to use 300zx axle? |
i found the thread through searching google but when i open the link it says: You do not have permission to view this topic !!!
the thread title was: New diff upgrade in the works! R200 350Z DIFF! |
Weird... That's the title for sure. Maybe removed for some reason.
Like te idea of this upgrade, please post if there's other projects like this going on out there. :) |
most likely removed because he was trying to market that stuff without being a sponsor. He should host that stuff elsewhere.
guess that kit uses custom driveshafts?
I think he talked about using the stock shafts, one Nissan axle had the same bolt pattern. Correct me if I'm wrong here.
yeah i think i remember something about the same bolt pattern
the oem driveshafts bolt straight up to the nissan diff. Pretty much if you mount it in the same spot as the oem diff, you use stock axles and find a way to custom mount the driveshaft to the diff flange.
the s2000 oem driveshafts? does the 350z diff has 6 bolt flanges?, as earlier R200s have either 5bolt or a 3x2 bolt pattern...
that would be easy enough, just get a custom one piece shaft and spend a day making mounts. |
