Nissan differentials in S2K.
Old Apr 26, 2010 | 11:03 AM
B5254T4's Avatar
Default Nissan differentials in S2K.
Read about a guy using a 350z axle here a while ago but can't find the thread, 1 hour of searching...
Anyone else tried to build your own kit? Most common to use 300zx axle?
Old Apr 26, 2010 | 11:38 AM
buzz944's Avatar
i found the thread through searching google but when i open the link it says: You do not have permission to view this topic !!!
the thread title was: New diff upgrade in the works! R200 350Z DIFF!
Old Apr 26, 2010 | 11:43 AM
B5254T4's Avatar
Weird... That's the title for sure. Maybe removed for some reason.
Like te idea of this upgrade, please post if there's other projects like this going on out there.
Old Apr 26, 2010 | 12:15 PM
kevos2k's Avatar
inline pro makes a kit
http://www.inlinepro.com/s1/p-31-s2000-diff-kit.aspx
Old Apr 26, 2010 | 12:45 PM
fatjoe10's Avatar
most likely removed because he was trying to market that stuff without being a sponsor. He should host that stuff elsewhere.
Old Apr 26, 2010 | 08:06 PM
3AM's Avatar
3AM
guess that kit uses custom driveshafts?
Old Apr 27, 2010 | 11:33 AM
B5254T4's Avatar
I think he talked about using the stock shafts, one Nissan axle had the same bolt pattern. Correct me if I'm wrong here.
Old Apr 27, 2010 | 11:52 AM
buzz944's Avatar
yeah i think i remember something about the same bolt pattern
Old Apr 27, 2010 | 12:44 PM
fatjoe10's Avatar
the oem driveshafts bolt straight up to the nissan diff. Pretty much if you mount it in the same spot as the oem diff, you use stock axles and find a way to custom mount the driveshaft to the diff flange.
Old Apr 27, 2010 | 03:47 PM
3AM's Avatar
3AM
the s2000 oem driveshafts? does the 350z diff has 6 bolt flanges?, as earlier R200s have either 5bolt or a 3x2 bolt pattern...
that would be easy enough, just get a custom one piece shaft and spend a day making mounts.
