nitrous install question
For those of you with Nitrous, wanted to know how you ran your lines. From the trunk. Is there a drain plug? Did you have to drill? And also how you ran your vaccuum lines (for a dry kit) for the intake and the fuel pressure regulator. I have a Zex kit that's been sitting in my closet for a while and I am probably going to drop it in for a little bit. Pictures would help too!
I would take pictures but you wouldn't be able to see anything
I ran the bottle line right by the drivers seat through the conduit on the side, through the hole in the firewall. I mounted the NMU in the airbox, and the nozzle up through the resonator into the intake.
i ran mine around behind the spare tire, thru the passenger side panels and up to the firewall. mounted the NMU on the frame by the oil filter. and have all the lines hidden to make it look like a sensor on the intake.
but dont tell anyone.
if you need any help setting it up, PM me.
chris
but dont tell anyone.if you need any help setting it up, PM me.
chris
S2KJimmy
Mar 6, 2004 06:40 AM
