no oil level reading on dipstick
Old Nov 10, 2014 | 05:36 PM
zeroptzero's Avatar
Originally Posted by Gotpepsi
Originally Posted by s2k_Doug67' timestamp='1415670095' post='23400435
I recently went to check my oil level and when i pulled the dipstick it, wiped it, put it back in, and checked it; there was no oil on it. Only a small amount on the very tip of the dipstick. So I turned the car, let it warm up to three bars, shut it off, and then waited 5 minutes before checking again. Same thing, only a small amount on the very tip of the dipstick. I got an oil change about 1500 miles ago, so there should be plenty of oil in the engine. Just looking for an explanation to why the dipstick is showing that the engine has no oil?
On a lot of other cars 1,500 miles seems like nothing on oil; however, on our s2000s 1,500 miles could burn through a quart of oil or more depending on how you drive. There is nothing wrong with the dipstick, if that's what you are asking, the car is simply low on oil! The dipstick looks like this
|H<><><><><>L|
When you are at the L mark, you are exactly one quart shy. Burning through a quart of oil in 1,500 is not uncommon, so there is nothing to be alarmed about. If you want your engine to last, you should top her off. Make it a habit to check the oil every time you get gas or every 400 miles.
Dip sticks don't lie! BUT! They do have two sides.
Meaning- Make sure you check both sides and go with the lowest reading.
Yup, if you are at the Lower of the <> marks then you are about 1 quart low, but if the level is at the bottom of the dipstick then you are more like 2 quarts low. There is a long distance between the bottom of the dipstick and the first of the <> L marks.
Old Nov 10, 2014 | 05:46 PM
bgoetz's Avatar
Originally Posted by yamahaSHO
Originally Posted by fernando.' timestamp='1415670798' post='23400453
I top up my oil regularly, like once a week. I'd say I add around 2 quarts between oil changes, and I do my oil changes every 5,000km's (3,100 miles)
Also, on every single car ever made it's exactly a quart from the low hashmark to the high hashmark, or L to F, or dot to dot, or whatever other form the dipstick can vary from.
I know AP1's burn oil, but JEEBUS!
My oil is still at the full mark after 6 track days and 2 AutoX's, plus some street driving.
You also have an AP2 . IDK why these threads always turn into a place for those who don't consume oil to make sure the rest of the world knows that they don't consume oil. If your S2k doesn't consume oil then great, take the extra $100 a year and buy something nice!! But coming onto threads and saying "my s2k doesn't consume oil" does nothing for the thread except make the OP think their car is broken, which it is NOT (although after running it on no oil I am sure it isn't better for it). The point is if you have been on these forums long enough then you know some consume over 1qt per 1k and run flawlessly and some don't consume a drop. So what purpose does saying your 1 of 75% that don't do for the OP.
Sorry, not trying to be a d!ck, but man every single one of these end up here. BTW the oil is consumed, I argue burnt isn't necessarily accurate.
Old Nov 10, 2014 | 05:47 PM
darcyw's Avatar
i check my oil cold with the car on level ground every time before i drive- its not a DD. why bother starting the car and warming it up before checking the oil level? i'm just asking.
darcy
Old Nov 10, 2014 | 06:15 PM
arsenal's Avatar
Why would you start the car and let it warm up to check it again?
Old Nov 10, 2014 | 06:18 PM
zeroptzero's Avatar
darcy
You can check it cold or hot, just be consistent once you choose to go by cold readings.
One other flaw is taking the reading on the first pull of the dipstick, you need to pull out the dipstick wipe it clean and reinsert, and then take the reading after that. I've seen the dipstick indicate full on the first pull, then after wiping and reinserting the reading was down to the Low mark. Something to keep in mind.
Old Nov 10, 2014 | 07:08 PM
s2k_Doug67's Avatar
Originally Posted by civdaddy
Just curious, how long have you owned the car and was that your first oil change?
Ive owned the car for two and half years and have done numerous oil changes. The car has never consumed this much oil before, but I guess Im just gonna have to top it off more often.
Old Nov 10, 2014 | 08:02 PM
s2k_Doug67's Avatar
Originally Posted by JFUSION
Fill it back up and check it more regularly, like every time you fill with gas. I would avoid any hard cornering and high rpm use when the oil level gets that low that's when the damage can occur.
I think the very bottom of the dipstick is more than one quart shy, the bottom of the H XXXX L range is closer to one quart shy, but the bottom of the dipstick is more like 2 quarts shy. That is the dangerous zone.
Good to know, thanks. Definitely wanna stay away from there aha.
Old Nov 10, 2014 | 08:45 PM
arsenal's Avatar
You can check it cold or hot, just be consistent once you choose to go by cold readings. One other flaw is taking the reading on the first pull of the dipstick, you need to pull out the dipstick wipe it clean and reinsert, and then take the reading after that. I've seen the dipstick indicate full on the first pull, then after wiping and reinserting the reading was down to the Low mark. Something to keep in mind.
When hot, how long does it take all the oil to drain in the pan to get a true reading?
Old Nov 10, 2014 | 09:27 PM
yamahaSHO's Avatar
Originally Posted by bgoetz
Originally Posted by yamahaSHO' timestamp='1415672511' post='23400507
[quote name='fernando.' timestamp='1415670798' post='23400453']
[/quote]
I sorta, maybe, kinda, probably acknowledged the AP1 thing... I am also comparing street driving to considerably more stressful driving.
It's a lot of damn oil. That's poor motor Subaru territory.
Oh... And get over it.
Old Nov 11, 2014 | 07:14 AM
zeroptzero's Avatar
I believe the owner's manual says to take a reading 5 minutes after shutdown when hot.
