No "pssshh" sound when opening gas cap.
Can someone help me diagnose this problem or where to check for a leak?
Usually when you fill up your cas tank you hear a vacum noise when opening the cap.
That's not happening for me.
Originally Posted by ayS,Nov 13 2005, 05:52 PM
what's the cause of the "pshhhh" when you open your gas tank? pressure caused from?
My S2000 has an almost unnoticeable sound when the cap is removed compared to my wife's PT Cruiser, which has a very pronounced vacuum suck when the cap is unscrewed.
Of course, it also depends on how long the vehicle has been operated. If you start it up and then go to the corner gas station, not much vacuum will have built up. Once the car is parked for a while the pressure will slowly equalize.
