No signal to crank sensor help needed
Old Feb 1, 2011 | 09:17 AM
Kitesurfer s2000's Avatar
Default No signal to crank sensor help needed
Its not the immobiliser causing no spark. I have searched but found nothing.
The gararge has traced it down to no signal to the crank sensor.
He cannot find out what voltage its ment to have ie 5 or 10v?.
2 cannot find a wiring diagram for the crank sensor.
This is starting to really cost me guys. Cheers guys need help .
Old Feb 2, 2011 | 05:06 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If one can not determine which voltage he is looking for, then he can not conclude that the crank sensor uses a reference signal.
Are they following the Honda book?
Old Feb 2, 2011 | 06:19 AM
durtbikedude365's Avatar
If you removed the head, is the ground wire on the back of the head tightened? If not this will cause a complete lack of spark and the car will not start.
skylinegtr35
Apr 4, 2018 05:00 AM
Kitesurfer s2000
Feb 1, 2011 12:20 PM
Locost47
Mar 17, 2010 01:52 PM
12Penske
Apr 11, 2009 07:13 AM
deebo
Apr 28, 2005 11:53 PM
